HDMI to VGA Active Adapter
CAC-1300 The Club 3D is an active HDMI™ to VGA signal converter. It accepts HDMI™ input from HDMI™ enabled Desktop or Laptop and converts to a legacy analog VGA output allowing the use of analog VGA Televisions, Monitors and Projectors. The adapter offers hassle free plug and play functionality and is powered by the HDMI™output.
The HDMI™ interface in the adapter consists of two main lanes for HDMI™ data, AUX channel, HPD signal and power. The VGA output is compliant to VSIS standard and supports up to WUXGA RB timings.
The adapter works with AMD, Nvidia and Intel Graphic Solutions and supports AMD Eyefinity™.
Connector 1:
HDMI™ Male
Connector 2:
VGA Female
Club 3D Graphics cards and other AMD, Nvidia or Intel graphics solutions with a HDMI™ output to any VGA compatible Television, Monitor or Projector.
Maximum resolution supported: 1920 x 1200p @ 60Hz
Notes:
· This adapter does not convert a VGA output to HDMI™.
· VGA displays do not support HDCP protected (encrypted) content such as DVD movies.
· HDMI™ adapters are unable to transmit HDCP enabled content to a VGA display and is not intended for use with Blu-ray or DVD players..
*The features of this adapter are subject to the capabilities of the HDMI™ source device and graphics solution.
