Micro HDMI™ to HDMI™ 2.0 4K60Hz Cable, Male/Male 1 M./ 3.28 Ft.
CAC-1351 The Club 3D Micro HDMI™ to HDMI™ 2.0 Cable delivers an UHD resolution signal for clear, natural pictures and sound. It enables you to connect your Digital Camera/Camcorder, Mini PC, Pico Projector or other device with Micro HDMI™output to a 4K UHD TV, monitor or projector with HDMI™ input. It fully supports the Premium High Speed HDMI™ with Ethernet’ specification, ensuring that video up to 4K UHD 3840x2160p at 60Hz is supported, as well as audio and data streams.
The cable combines the unmatched signal quality and convenience of HDMI™ connectivity with the power and flexibility of home entertainment networking. The Micro HDMI™ to HDMI™ 2.0 Cables are premium quality making them ideal for use with (Semi) Professional equipment supporting Ultra High Definition Resolutions.
Mini HDMI™ to HDMI™ 2.0 Cable  Male / Male 1 M./ 3.28 Ft.
HDMI™ 1.4 to DisplayPort™ 1.1  Adapter
Maximum resolution:
3840x2160p @60Hz and 1920x1080p 3D video @ 120Hz
Connector 1:
Micro HDMI™ male
Connector 2:
HDMI™ male
Product Name: Micro HDMI™ to HDMI™ 2.0 4K60Hz Cable Male/Male
Product Series: Accessories
Weight: 45gr
Cable length: 1 Meter/3.28 Feet
Item Code: CAC-1351
EAN Code: 8719214470678
UPC Code: 841615100859
• Backwards compatible with earlier HDMI™ versions
• Compliant to Premium High Speed HDMI™ with Ethernet specification
• Video Resolutions Support 4K at 60Hz
• Plug & Play and fully Bi-Directional
All
n the Box:
Club 3D Micro HDMI™ to HDMI™ 2.0 4K60Hz Cable, 1 Meter/3.28 Feet Male/Male
