USB 3.1 Type C to Gigabit Ethernet Active Adapter
CAC-1500 The Club 3D is an active Ethernet converter. This USB-C to Gigabit Ethernet Adapter is the easiest solution for connecting your USB 3.1 Type C source device to a high speed Ethernet Network. The Ethernet adapter is compact and highly portable. Powered by the USB-C port, the adapter requires no external power and is ideal for use with notebooks and Ultrabooks.
Reliable and fast connection
The USB-C to Gigabit Ethernet adapter gives you direct, wired access to a fast ethernet network at places where a wireless connection is slow, inconsistent or not available at all. Benefit from the reliability and speed a wired Ethernet connection offers for online gaming, downloading large files or streaming high resolution media.
The USB-C to Ethernet Adapter supports all USB-C devices and operating systems, including Apple OS X, Windows 7, 8.1 and 10 and Google Chrome OS. No driver installation needed. Simply plug it in and connect to the Ethernet.
USB 3.1 Type C to HDMI 1.4  Active Adapter
Premium High Speed HDMI 2.0 UHD Extension Cable M/F 3m/9.84ft
HDMI to VGA Active Adapter
Connector 1
USB Type-C Male
Connector 2
RJ45 Gigabit Ethernet Female
Product Name: USB Type-C to USB 3.1 Type C to Gigabit Ethernet Active Adapter
Product Series: Accessories
Weight: 20 gr.
Cable Length: 150mm
Item Code: CAC-1500
EAN Code: 8719214470074
UPC Code: 841615100163
Reversible USB Type-C Male connector
RJ45 Ethernet female port
Supports 10/100M/1G Broad access network
Supports a Wake-On-LAN.
Supports a USB 3.0 Power Saving Mode •Activity and Link LED indicators
Powered by USB port (no external power needed)
Operating Systems
Microsoft Windows
Chrome OS
In the Box
CAC-1500 USB Type-C to USB 3.1 Type C to Gigabit Ethernet Active Adapter
