USB Type-C to HDMI™ 1.4  Active Adapter
CAC-1501 The Club 3D is an active HDMI™ 3D signal converter. This USB-C to HDMI 1.4a Adapter is the easiest solution for connecting your USB Type C source device featuring DisplayPort™ Alternate Mode to an HDMI™ enabled High Resolution Monitor, Television or Projector. The HDMI™ adapter is compact and highly portable. Powered by the USB-C port, the adapter requires no external power and is ideal for use with notebooks and Ultrabooks.
Supports up to 4K Resolution
The USB-C to HDMI™ 1.4a adapter supports (U)HD resolutions of up to 4K UHD @ 30Hz for a clear, sharp picture. Use the adapter to play games, view video or browse the internet from your USB-C enabled device on an external flatscreen TV or display device. Supporting up to 8 channels of audio, the adapter provides high-definition digital audio and video.
The USB-C to HDMI™ 1.4a Adapter supports all USB-C devices with DisplayPort™ ALT mode and operating systems, including Apple OS X, Windows 7, 8.1 and 10 and Google Chrome OS.
USB 3.1 Type C to Gigabit Ethernet Active Adapter
Micro HDMI™ to HDMI™ 2.0 4K60Hz Cable, Male/Male 1 M./ 3.28 Ft.
Connector 1
USB Type-C Male
Connector 2
HDMI 1.4 Female
Product Name: USB 3.1 Type C to HDMI 1.4a Active Adapter
Product Series: Accessories
Weight: 56 gr
Cable length: 180 mm
Item Code: CAC-1501
EAN Code: 8719214470036
UPC Code: 841615100125
Reversible USB Type-C connector
Compliant to VESA DisplayPort™ Alt Mode Standard
Compliant to HDMI™ 1.4a, for up to 10.2Gbps data rate
Supports full link training, fast link training and no link training
Repeater for HDCP 1.3
Supports 3D Video formats up to 1080p @ 120Hz
Supports Monitor resolutions up to 4K UHD 3840x2160 @ 30Hz
Powered by USB port (no external power needed)
Compatibility
Operating Systems
Microsoft Windows
Google Chrome OS
In the Box
Club 3D CAC-1501 USB 3.1 Type C to HDMI™ 1.4a 3D Active Adapter
