Mini DisplayPort™ 1.4 HBR3 Cable  Male / Male 2M / 6.56 Ft.
CAC-1164 The Club 3D Mini DisplayPort™ 1.4 HBR3 cable enables the connection of your Mini DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other Mini DisplayPort™ supported device. Mini DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
Mini DisplayPort™ 1.2 Cable to HDMI™ 2.0 UHD 4K60Hz Active Adapter Male/Male 3M/ 9.84Ft
Mini DisplayPort™ 1.2 to HDMI 2.0
Maximum resolution:
- 8K @ 60Hz
- 2 x 4K @60Hz
- 4K at 120 Hz
Without compression (DSC) DisplayPort 1.4 can support up to: - 5K @ 60Hz
Connector 2: Mini DisplayPort™ Male
Product Name: Mini DisplayPort™ to DisplayPort™ 1.4 HBR3 8K60Hz Cable Male / Male 2 mtr. / 6.56 Ft.
Product Series: Accessories
Weight: 91 gr
Item Code: CAC-1164
EAN Code: 8719214470647
UPC Code: 841615100828
• Support resolutions up to 8K @ 60Hz or 2 x 4K @ 60Hz
• Bi-Directional
Operating System Support
All
In the box
