CAC-1156 The Club 3D CAC-1156 is a passive HDMI™ signal converter. The Mini DisplayPort™ 1.1a to HDMI™ 1.4a VR Ready Adapter is the easiest solution for connecting your Mini DisplayPort™ 1.1a enabled Game PC/ Laptop/ Tablet to an HDMI™ 1.4 enabled (U)HD Television, monitor or Projector. The adapter is fully compliant to HDMI™ 1.4a specification allowing for 3Gbps TMDS through-put per channel. The interface in the adapter has three lanes for HDMI data, clock, HPD signal and power, offering a total TMDS throughput of 9Gbps.
Supports up to Full HD Resolution at 120Hz.
The Mini DisplayPort™ 1.1a to HDMI™ 1.4a VR adapter supports (U)HD resolutions of up to 4K UHD 3840 x 2160p @ 30Hz or 1920 x 1080p ~120Hz for a clear, sharp picture. Use the adapter to play games, view video or browse the internet from your Mini DisplayPort™ 1.1 enabled device in (Ultra) high- resolution. Supporting up to 8 channels of audio, the adapter provides High Definition digital audio and video. This is also an ideal solution for use with any VR Device.
Mini DisplayPort 1.2 Cable to HDMI UHD 4K60Hz Active Adapter Male/Male 3M / 9.84Ft
Mini DisplayPort 1.2 to HDMI 2.0 Active Adapter
Product Name: Mini DisplayPort™ 1.1 to HDMI™ 1.4 VR Passive Adapter
Product Series: Accessories
Weight: 40 gr
Cable length: 200 mm
Item Code: CAC-1156
EAN Code: 8719214470142
UPC Code: 841615100255
• Compliant to DisplayPort Specification 1.1a
• Compliant to HDMI™ 1.4a Specification, data rate up to 3Gbps per TMDS channel. Total throughput 9Gbps
• Supports 4K, 2K and 3D video formats over HDMI
• Supports DisplayPort all 4 levels of output and all 4 levels of pre-emphasis
• Repeater for HDCP 1.3
• 24-bit color and 4:4:4 color sampling
• YCbCr 4:4:4 and YCbCr 4:2:2 8/10/12 bpc capability
• Supports UHD resolutions up to 3840 x 2160p @ 30Hz and 1920 x 1080p ~120Hz 3D
• Supports AMD Eyefinity feature
Connector 1:
Mini DisplayPort™ 1.1 Male
Connector 2:
HDMI™ 1.4 Female
Operating System Support
Windows, Apple OS X
In The Box
Club 3D Mini DisplayPort™ 1.1 to HDMI™ 1.4 VR Passive Adapter
No extra information found.
