Mini DisplayPort™ to HDMI™ Passive Adapter
CAC-1101 The Club 3D is a passive HDMI™ signal converter. The Mini DisplayPort™ to HDMI™ Adapter is the easiest solution for connecting your Mini DisplayPort™ enabled Desktop or Laptop to a HDMI™ enabled High Definition Television, Monitor or Projector.
The adapter works with AMD, Intel® and Nvidia® graphics solutions and supports a maximum resolution of 1920x1200p @ 60Hz. Simply connect the Mini DisplayPort™ (male) end of the connector to your computer and plug your existing HDMI™ cable from the display into the HDMI™ (female) adapter.
Setup requires no software installation.
The circuitry built into the adapter seamlessly converts the Mini DisplayPort™ video signal into a HDMI™ digital video signal.
Mini DisplayPort™ 1.1 to HDMI™ 1.4 VR ready Passive Adapter
Mini DisplayPort™ 1.4 HBR3 Cable  Male / Male 2M / 6.56 Ft.
Connector 2: HDMI™ Female
Product Name: Mini DisplayPort™ to HDMI™ Passive Adapter
Product Series: Accessories
Weight: 56 gr
Cable length: 150 mm
Item Code: CAC-1101
EAN Code: 8717249408499
UPC Code: 854365005138
• Club 3D Mini DisplayPort™ to HDMI™ Passive Adapter
• Compliant to DisplayPort™ 1.1a Specification
• Supports Dual Mode DisplayPort™ (DP++)
• Compliant to HDMI™ 1.3 specification
• Supports resolutions up to WUXGA 1920x1200p
• No external power needed
• Supports AMD, Nvidia® and Intel® graphics solutions
Compatibility
Operating Systems
Microsoft Windows
In the Box
CAC-1101 Mini DisplayPort to HDMI™ Passive Adapter
No extra information found.
