Mini DisplayPort to DVI-D SL Passive Adapter
CAC-1100 The Club 3D is a passive DVI signal converter. The Mini DisplayPort™ to DVI-D Adapter is the easiest solution for connecting your Mini DisplayPort™ enabled Desktop or Laptop to a DVI enabled High Definition Television, Monitor or Projector.
The adapter works with AMD, Intel® and Nvidia® graphics solutions and supports a maximum resolution of 1920x1200p @ 60Hz. Simply connect the Mini DisplayPort™ (male) end of the connector to your computer and plug your existing DVI-D cable from the display into the DVI (female) adapter.
Setup requires no software installation. The circuitry built into the adapter seamlessly converts the Mini DisplayPort™ video signal into a DVI digital video signal.
Please note that this adapter is for digital signals only and will not fit analog DVI ports.
This professional grade adapter-cable is ceritfied by Vesa
Mini DisplayPort to DVI-D SL Active Adapter
Product Name: Mini DisplayPort™ to DVI-D Single Link Passive Adapter
Product Series: Accessories
Item Code: CAC-1100
EAN Code: 8717249408482
UPC Code: 854365005121
• Compliant to DisplayPort™ 1.1a Specification
• Supports Dual Mode DisplayPort™ (DP++)
• Supports resolutions up to WUXGA 1920x1200p @ 60Hz
• No external power needed
• Supports AMD, Nvidia® and Intel® HD/ Iris™ graphics solutions
• Vesa ceritfied
Connector 1:
Mini DisplayPort™ Male
Connector 2:
DVI-D Single-Link Female
Operating Systems
Microsoft Windows, Apple OS X
• Boxsize:280 x 60 x 35mm.
• Cable: 170 x 44 x 18mm.
• Weight: 56 gr.
In the Box
CAC-1100 Mini DisplayPort™ to DVI-D Single Link Passive Adapter
No extra information found.
