DisplayPort™ 1.2 Cable to HDMI™ 2.0 UHD 4K60Hz Active Adapter Male/Male 3M/ 9.84Ft
CAC-1073 The Club 3D is an active HDMI™ signal converter. The DisplayPort™ 1.2 to HDMI™ 2.0 Cable Active Adapter is the easiest solution for connecting your DisplayPort™ 1.2 enabled Game PC or Laptop to an HDMI™ 2.0 enabled 4K UHD Television, monitor or Projector. The adapter is fully compliant to HDMI™ 2.0 specification allowing for 6Gbps TMDS throughput per channel. The interface in the adapter has three lanes for HDMI data, clock, HPD signal and power, offering a total TMDS throughput of 18Gbps.
Supports up to 4K UHD Resolution at 60Hz. The DisplayPort™ 1.2 to HDMI™ 2.0 Cable Active Adapter supports (U)HD resolutions of up to 4K UHD 3840x 2160p @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video or gameplay. Use the adapter to play games, view video or browse the internet from your DisplayPort™ 1.2 enabled device in (Ultra) high-resolution. Supporting up to 8 channels of audio, the adapter provides Ultra High Definition digital audio and video. It is the ideal solution for anyone who wants to enjoy 4K UHD/ 60 game-play but lacks a native HDMI™ 2.0 output in their system configuration.
HDMI™ 1.4 to DisplayPort™ 1.1  Adapter
USB 3.1 Type C to DisplayPort™ 1.2
Maximum resolution:
4K UHD 4096x2160p @60Hz 8Bit BPC and 1920x1080p 3D video @120Hz
Connector 1: DisplayPort™ 1.2 Male
Connector 2: HDMI™ 2.0 Male
Product Name: DisplayPort™ 1.2 Cable to HDMI™ 2.0 UHD 4K60Hz Active Adapter
Product Series: Accessories
Weight: 160gr
Cable length: 3 meters / 9.84 feet
Item Code: CAC-1073
EAN Code: 8719214470586
UPC Code: 841615100767
• Supports UHD resolutions up to 4096 x 2160p @ 60Hz, 8Bit BPC
Compatibility
Supports AMD GCN cards, Nvidia® Maxwell cards and Intel® HD 4600 Graphics and newer. Not intended for older architectures (such as Intel Haswell HD Graphics / NVidia Kepler 5xx/6xx series Graphics)
Operating Systems
Windows 10, 8.1, 7 32 & 64 bit
Apple OS X 10.11, 10.10, 10.9, 10.8
In the Box
DisplayPort™ 1.2 Cable to HDMI™ 2.0 Active UHD 4K60Hz Adapter
