CAC-1066 The Club 3D DisplayPort™ 1.4 HBR3 cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32. It features a locking DisplayPort™ connector providing a secure, dependable connection. Simply press the built-in one- touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
Maximum resolution:
- 8K @ 60Hz
- 4K at 120 Hz
Without compression:
(DSC) DisplayPort 1.4 can support up to: - 5K @ 60Hz
Product Name:DisplayPort™ 1.4 HBR3 Cable 8K60Hz Male / Male 4m./13.12ft.
Product Series: Accessories
Weight: 281 gr
Cable length: 4 meters / 13.12 feet
Item Code: CAC-1066
EAN Code: 8719214470623
UPC Code: 841615100804
• Support resolutions up to 8K @ 60Hz
Operating System Support:
All
