CAC-1064 The DisplayPort™ Ver. 1.2 cable enables the connection of your DisplayPort™ supported Gaming PC or Laptop to an (Ultra) High Definition Monitor or other DisplayPort™ supported device. It features locking DisplayPort™ connectors providing a secure, reliable connection.
Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation that can damage it. Supports HBR2, total data throughput 21.6Gbps 4K UHD resolutions up to 3840x2160p @60Hz and 1080p Full HD 3D video.
Maximum resolution:
3840x2160 @ 60Hz and 1920x1080p 3D video @ 120Hz
Connector 1: DisplayPort™ 1.2 Male
Connector 2: DisplayPort™ 1.2 Male
DisplayPort™ Cable size 3 meters or 9.8 feet
DisplayPort™ 1.2 compatible - supports version 1.1a
Supports resolutions up to [email protected] 60Hz and 3D video
Supports all (U)HDTV resolutions including 1080p and 4K UHD
Latching connectors for a secure, reliable connection
Supports HBR2, up to 5.4 Gbps per lane throughput - 21.6 Gbps total
Supports AMD, Nvidia and Intel graphics solutions
Supports Windows and Apple OS X
DisplayPort™ Cable weight 160 grams
ITEM code: CAC-1064
EAN code 8717249401100
UPC code 854365005930
