DisplayPort™ to DVI Dual Link Converter Active Adapter
CAC-1051 The Club 3D DisplayPort™ to DVI Dual Link Active Adapter Converter is the easiest solution for connecting your DisplayPort™ enabled Desktop or Laptop to a DVI-D enabled High Definition Television, Monitor or Projector. The adapter works with AMD, Intel and Nvidia graphics solutions and supports a maximum resolution of 2560 x 1600p @ 60Hz. Simply connect the DisplayPort™ (male) end of the connector to your computer and plug your existing DVI-D cable from the display into the DVI (female) adapter.
Setup requires no software installation. The adapter seamlessly converts the
DisplayPort™ video signal into a DVI Digital video signal.
Ideal solution for AMD Eyefinity and other Multi Monitor configurations. Please note that this adapter is for digital signals only and will not fit analog DVI ports.
DisplayPort™ 1.2 to HDMI™ 2.0 UHD Active Adapter
DisplayPort™ to DVI-D SL Active Adapter
DisplayPort™ 1.1 to HDMI™ 1.4 VR ready Passive Adapter
Connector 2: DVI-D Female
Connector 3: USB 2.0 Male
Product Name: DisplayPort™ to Active DVI Dual Link 330MHz Stereo 3D Gaming cable
Product Series: Accessories
Item Code: CAC-1051
EAN Code: 8717249408475
Length Displayport cable: 370 mm
Length USB 2.0 cable: 460 mm
Length DVI cable: 106 mm
Width DVI cable: 54 mm
Height: DVI cable: 23 mm
Netto Weight: 180 grams
Gross Weight: 220 grams
DisplayPort: 1x DisplayPort™
DVI: 1x Dual Link 330MHz DVI-D
USB: 1x USB 2.0 Power Supply
Max. Res. digital: 3840 x 2160
Max. Res. analog: 2048 x 1536
HDTV: YES
DPCP: YES
Bandwidth
Dual Link, 330MHz
Club 3D DisplayPort™ to Active DVI Dual Link 330MHz Stereo 3D Gaming cable
Club 3D graphics cards with DisplayPort connector and system with available USB Port or any DisplayPort compatible device. Compatible with AMD Eyefinity™.
AMD EYEFINITY
