DisplayPort™ to HDMI™ Passive Adapter
CAC-1001 The Club 3D is a passive HDMI™ signal converter. The DisplayPort™ to HDMI™ Adapter is the easiest solution for connecting your DisplayPort™ enabled source device to an HDMI™ enabled High Definition Television, monitor or Projector.
The adapter works with AMD, Intel and Nvidia graphics solutions and supports a maximum resolution of 1920x1200p. Simply connect the DisplayPort™ (male) end of the connector to your computer and plug your existing HDMI™ cable from the display into the HDMI™ (female) adapter. Setup requires no software installation. The circuitry built into the adapter seamlessly converts the DisplayPort™ video signal into a HDMI™ video signal.
Supports resolutions up to 1920 x 1200p @ 60Hz
DisplayPort™ 1.1 to HDMI™ 1.4 VR ready Passive Adapter
DisplayPort™ 1.2 to HDMI™ 2.0 UHD Active Adapter
DisplayPort™ 1.4 HBR3 Cable Male / Male 4M /13.12ft.
Connector 2: HDMI™ Female
Product Name: DisplayPort™ to HDMI™ Passive Adapter
Product Series: Accessories
Weight: 56 gr
Cable length: 180 mm
Item Code: CAC-1001
EAN Code: 8717249408444
UPC Code: 854365005077
• Club 3D DisplayPort™ to HDMI™ Passive Adapter
• Compliant to DisplayPort™ 1.1a Specification
• Compliant to HDMI™ 1.3 specification
• Supports resolutions up to WUXGA 1920x1200p
• No external power needed
• Supports AMD, Nvidia® and Intel® HD/ Iris™ graphics solutions
Compatibility
Operating Systems
Windows 10, 8.1, 7 32 & 64 bit
Apple OS X 10.11, 10.10, 10.9, 10.8
In the Box
Club 3D CAC-1001 DisplayPort to HDMI™ Passive Adapter
AMD EYEFINITY
