DVI-D to HDMI™ Passive Adapter
CAA-DMD>HFD3 The Club 3D DVI-D to HDMI™ Passive Adapter enables the connection of your DVI-D supported Gaming PC, workstation or laptop to an HDMI™ supported High Definition Television, Monitor or Projector. It transfers a digital video and a digital audio signal (up to 7.1 channel) from your graphics solution to the HDMI™ Display Device. Supports resolutions up to WUXGA 1920x1200p @60Hz. Supports 1080p Full HD video playback.
Compatible with AMD, Nvidia and Intel graphics solutions.
HDMI™ to VGA Active Adapter
DisplayPort™ to DVI-D Single-Link Passive Adapter
DisplayPort™ to DVI Dual Link Converter Active Adapter
Maximum resolution:
Connector 1: DVI-D Male
Connector 2: HDMI™ Female
Supports resolution:
Supports HDTV resolutions up to 1080p Full HD
Screw connector for a secure, reliable connection
Supports AMD, Nvidia and Intel graphics solutions
Weight 39 grams
ITEM code: CAA-DMD>HFD3
EAN code: 8717249407911
UPC code: 854365005053
No extra information found.
