USB 3.1 Type C to USB 3.0 Type A Adapter
CAA-1521 The Club 3D USB 3.1 Type C to USB 3.0 Type A Adapter enables the connection of your existing USB peripherals, storage devices and docking stations with the common Type A male connector plug to the latest Laptops, professional tablets and Ultrabooks featuring USB 3.1 Type C outputs.
The adapter is backwards compatible and supports USB 2.0 as well. The USB 3.0 SuperSpeed specification ensures a bitrate of 5Gbps for fast transfer of large files.
Supports Windows, Apple OS X and Chrome OS.
USB 3.1 Type C to DisplayPort™ 1.2
USB 3.1 Type-C Cable M/M 0.8M/2.6ft  10Gbps, 4K60Hz, Power Delivery
Connector 1: USB 3.1 Type-C Male
Connector 2: USB 3.0 Type-A Female
The USB 3.1 Type-C to USB 3.0 Type-A Adapter works with all Laptops, Tablets and Desktop PC's featuring a USB Type-C output.
Use the adapter to connect your existing USB peripherals, storage devices and docking stations with the common Type-A male connector plug to your USB Type-C enabled system. The adapter is backwards compatible and supports USB 2.0.
Please refer to your device's user manual to confirm the specification and functionality of its USB Type-C port.
EAN Code: 8719214470425
UPC Code: 841615100545
Item Code: CAA-1521
