USB 3.0 Active Repeater Cable 5 m/ 16 ft Male/Female
CAC-1401 With this Club3D USB 3.0 Active Repeater Cable series (CAC-1401/CAC-1402/CAC-1403) you can go far beyond the standard USB Cable length limitation of 3 meters, without loss of Data Transfer Speed. The USB 3.0 Active Repeater Cables are fully Plug & Play and do not require any driver installation.
Just connect your external USB device like External HDD/NAS/Digital Camera or External USB Graphics to your system and have flexibility of the increased 5/10/15 meters of extra cable length. The CAC-140x Series support data transfer rates up to 5Gbps over the full length of the cable. The CAC-1402 and CAC-1403 are delivered with a power supply to ensure functionality of power hungry USB devices.
DisplayPort to DVI-D Single-Link Passive Adapter
HDMI to DVI-D Single Link Passive Adapter
Premium High Speed HDMI 2.0 UHD Extension Cable M/F 3m/9.84ft
Connector 1: USB 3.0 Male
Connector 2: USB 3.0 Female
USB 3.0 active specification
Supports data transfer speeds up to 5 Gbps
Extends 5 meters
Plug and play functionality
NO External power supply included*
Cable: 22AWG+25AWG+28AWG,OD:7.0m
No drivers required
Windows™ and Apple OS X™ compatible
What is included?
USB 3.0 Active Repeater Cable 5 meters / 16 feet
EAN: 8717249401209
UPC: 854365005299
