USB 3.0 Active Repeater Cable 15 m/ 49 ft Male/Female
CAC-1403 With this Club3D USB 3.0 Active Repeater Cable series ( CAC-1401/CAC-1402/CAC-1403 ) you can go far beyond the standard USB Cable length limitation of 3 meters, without loss of Data Transfer Speed. The USB 3.0 Active Repeater Cables are fully Plug & Play and do not require any driver installation.
Just connect your external USB device like External HDD/NAS/Digital Camera or External USB Graphics to your system and have flexibility of the increased 5/10/15 meters of extra cable length. The CAC-140x Series support data transfer rates up to 5Gbps over the full length of the cable. The CAC-1402 and CAC-1403 are delivered with a power supply to ensure functionality of power hungry USB devices.
USB 3.0 Active Repeater Cable 10 m/ 32 ft Male/Female
USB 3.0 Active Repeater Cable 5 m/ 16 ft Male/Female
Premium High Speed HDMI™ 2.0 UHD Extension Cable 3 m/ 9.84 ft Male/Female
Connector 1: USB 3.0 Male
Connector 2: USB 3.0 Female
Power adapter
Input 100-240V
50/60Hz 0.35A max
Output: 5V 2000mA
USB 3.0 SuperSpeed specification
Supports data transfer speeds up to 5 Gbps
Extends 15 meters
Plug and play functionality
External power supply included *
Cable: 22AWG+25AWG+28AWG,OD:7.0m
Microsoft Windows™ and Apple OS X™ compatible
* In most cases the power supply is not required with the exception of some USB HDD and high power wifi networking devices
What is included?
USB 3.0 Active Repeater Cable 15 meters / 49 feet
Power Adapter
EAN: 8717249401254
UPC: 854365005336
No extra information found.
