USB 3.0 Hub 4-Port with Power Adapter
CSV-1431 The SenseVision USB 3.0 Hub 4-Port with Power Adapter is designed in a stylish and sturdy aluminum casing and is very slim which makes it easy to carry around.
The CSV-1431 allows you simultaneous access to 4 x USB 3.0 ports from just one single USB 3.0 uplink. The CSV-1431 comes standard with a Power Adapter so that the user can connect even the most power-hungry USB devices like External HDD Drives, Digital Camera, Mobile Phones etc.
The 4 USB ports are all USB Type A and USB 3.0 compliant and downward compatible to USB2.0 standard, but this will have influence on the performance.
USB 3.0 3-Port Hub with Gigabit Ethernet
USB 3.0 Active Repeater Cable 15 m/ 49.21 ft Male/Female
USB 3.0 Active Repeater Cable 10 m/ 32.81 ft Male/Female
Product Name: Club 3D USB 3.0 Hub 4-Port with Power Adapter
Product Series: SenseVision
Weight: 70gr
Cable length: 100 mm
Item Code: CSV-1431
EAN Code: 8719214470128
UPC Code: 841615100224
Uplink: USB 3.0 Male x1
Voltage
USB bus powered 3.3V/500mA
Power Adpater 5V/2.5A or 5V/4A
Downlink: USB 3.0 x 4 female
Driver CD
Slim design with Aluminum Casing
Support auto switching between AC-power and USB-bus-power mode
Switching power adapter included; Output: DC 5V/2.5A or 5V/4A
Support Battery Charge 1.2 Fast Charge Function and Apple Charging
Compatible with USB 3.0 standard and downwards compatible with USB 2.0 standard
Support the following speed data rate as follows; Low-speed (1.5 Mbps) / Full-speed (12 Mbps) / High-speed (480 Mbps) / Super-speed (5 Gbps ) It works with Windows and Mac OS X
The minimum requirements for the pc are:
PC / Laptop / Tablet with free USB 3.0 Port
Supported Operating Systems:
No extra information found.
