USB Type C to VGA + USB 3.0 + USB Type C Charging Mini Dock
CSV-1532 The SenseVision USB Type C to VGA + USB 3.0 + USB Type C Charging Mini Dock is a portable and indispensable tool for your USB Type-C enabled laptop or Ultrabook featuring DisplayPort™ Alternate Mode. Add an analog VGA monitor with up to WQXGA 2560x1600p resolution through the D-Sub output while the USB 3.0 Type-A port connects your USB Sticks, Peripherals and HDD’s.
It also offers a Type-C PD input which charges your device with up to 60Watt at the same time. Supports Microsoft Windows® and Apple OS X, requires DisplayPort™ Alt Mode.
Model |
Product Name: USB 3.1 Type-C to VGA and USB Mini Docking Station |
Product Series: SenseVision |
Weight: 51 gr |
Connector length: 55mm |
Item Code: CSV-1532 |
EAN Code: 8719214470487 |
UPC Code: 841615100613 |
Interface |
USB 3.0 Type-C male x 1 |
Output Configuration |
D-Sub VGA female x 1 |
USB 3.0 Type-A female x1 (for Data) |
USB 3.0 Type-C female x1 (for Charging) |
In the package |
SenseVision USB 3.0 Type C to Ethernet and USB Mini Docking Station |
Quick install guide |
• Innovative Portable Design |
• Folding USB Type C Connector |
• Supports analog VGA monitor |
• Supports up to 270MHz video pixel clock |
• Supports up to WQXGA resolution (2560x1600p) |
• 1x USB 3.0 (3.1 Gen1) Type-A port for Data (max 5Gbps) |
• 1x USB Type C PD port (5V/ 1.5A, 20V/3A) |
• Requires Type C DisplayPort™ Alt Mode |
The minimum requirements for the PC are: |
CPU: AMD or Intel Dual Core CPU 2GHz or higher processor clock. |
GPU: AMD, Intel or Nvidia |
RAM: 1GB or higher |
USB port: Type C must support DisplayPort™ Alt Mode |
30MB of available disk space |
Supported Operating Systems: |
Windows 7 (32 & 64 Bit) |
Windows 8.1 (32 & 64 Bit) |
Windows 10 (32 & 64 Bit) |
Apple OS X |
2013 USB 3.1 Gen 2 Super Speed + SS+ 10Gbps SS/HS/FS/LS
DOCKING STATION
THUNDERBOLT TECHNOLOGY
