USB Type-C to DP 1.2 + USB 3.0 + Type-C Charging Mini Dock
CSV-1537 The SenseVision USB Type-C to DP 1.2 + USB 3.0 + Type-C Charging Mini Dock is a compact Mini Docking with DisplayPort™ 1.2 and USB outputs for your USB Type-C enabled laptop or Ultrabook. Add a 4K UHD monitor or TV with up to 3840x2160p UHD resolution through the DisplayPort™ 1.2 output while the USB 3.0 Type-A port allows you to use USB sticks, peripherals and HDD’s. It also offers a Type-C PD input which can charge your device with up to 60Watts at the same time. Works with Mac OS, Microsoft Windows® and Chrome OS.
For Video Signal the source device needs to support DisplayPort™ Alt Mode.
USB Type-C Gen 2 Active Cable 4K60Hz 10Gbps PD 100W M/M 1 m/ 3.28 ft
Product Name: USB 3.1 TypeC to DisplayPort™ 1.2 + USB 3.0 + USB Type C Charging Mini Dock
Product Series: SenseVision
Weight: 51 gr
Connector length: 55mm
Item Code: CSV-1537
EAN Code: 8719214470555
UPC Code: 841615100729
USB 3.0 Type-C male x 1
Displayport 1.2 female x1
USB 3.0 Type-A female x1 (for data)
SenseVision USB 3.1 Type C to Displayport + USB 3.0 + USB Type C Charging Mini Dock
• Innovative portable design
• Folding USB Type C host connector
• 1x DisplayPort™ 1.2
• 1x USB 3.0 Type-A port for Data*
• 1x USB Type C for Charging, PD5V/3A.20V/3A
• Max resolution 4K UHD 3840x2160p @ 60Hz*
• Supports both DisplayPort™ and TMDS signal formats (DP++)
• Supports Mac OS, Windows and Chrome OS
• Requires Source Device to support DisplayPort™ Alt Mode for Type C output
* 2 Lane DP Switch Supports and USB 3.0 and Only USB 2.0
GPU: AMD, Intel or Nvidia
RAM: 1GB or higher
USB port: 2.0/3.0 Type-C with DisplayPort™ Alt Mode
30MB of available disk space
Supported Operating Systems:
Windows 7 (32 & 64 Bit)
Windows 8.1 (32 & 64 Bit)
Windows 10 (32 & 64 Bit)
DOCKING STATION
THUNDERBOLT TECHNOLOGY
