CSV-1541 The SenseVision USB 3.0 Type-C to USB Type-A Data and Charging Hub is a compact tool which adds four common USB Type-A ports to your USB Type-C enabled device. Many of the latest Ultrabooks and Laptops lack a sufficient number of expansion ports, thus making it difficult to use your favorite peripherals like Mice, USB Storage and External HDD’s at the same time, while no port is left to charge your Smartphone, headset or other device. This USB Hub gives you four additional USB Type-A ports for Data and Power. It features fully integrated voltage regulators and Port 5 supports the comprehensive USB Battery Charging Specification 1.2 which supports the following three (Rapid) Charging modes: SDP, CDP and DCP. With this Hub, battery charging can now be done safely for a wide range of portable devices.
The current limit of USB charging is 500mA for USB 2.0 and 900 mA for USB 3.0. Depending on the device, Rapid Charging features limits between 1000mA and 2000mA. Rapid Charging allows charging at higher current than the USB Spec but requires both Host and connected devices to support this functionality. There are three supported USB Charging Modes:
• SDP: Standard Downstream Port (USB 2.0 500mA, USB 3.0 900mA charging + Data)
• CDP: Charging Downstream Port (up to 1500mA for supported devices + Data)
• DCP: Dedicated Charging Port (beyond 1500mA for supported devices, NO Data)
All major operating systems including Windows, Apple OS X, Chrome OS and Linux are supported without the need of installing a driver. Functionality depends on the USB Host controller in your device.
USB 3.0 Active Repeater Cable 15 m/ 49.21 ft Male/Female
USB 3.0 3-Port Hub with Gigabit Ethernet
USB 3.0 Active Repeater Cable 10 m/ 32.81 ft Male/Female
Product Name: USB 3.0 Type C to 4x USB Type A Hub
Product Series: SenseVision
Weight: 51 gr
Cable length: 185 mm
Item Code: CSV-1541
EAN Code: 8719214470531
UPC Code: 841615100712
USB 3.0 Type C x1
Voltage
1.2V Core Power
3.3V Suspend Power
5V Regulator for 5- 3.3V Output
USB 3.0 Type A x3
USB 3.0 Type A with BC 1.2 Charging support x1
SenseVision USB 3.0 Type C to 4x USB Type A Hub
• Reversible USB Type C connector (male)
• Compliant to USB 3.0 Specification, backwards compatible with USB 2.0 Specification
• USB 3.0 Data and Fast Charging through a single cable
• Supports USB 3.0 SuperSpeed data up to 5Gbps
• Supports USB Battery Charging Specification 1.2 (Port 5)
• Support for Vendor specific Charging Modes
• Works out of the box with Windows, Apple OS X, Chrome OS, no driver needed
• Works with all USB Type C enabled devices
GPU: AMD, Intel or Nvidia
RAM: 1GB or higher
USB 2.0, 3.0 or 3.1 Type C Output
Supported Operating Systems:
Windows 7 (32 & 64 Bit)
Windows 8.1 (32 & 64 Bit)
Windows 10 (32 & 64 Bit)
Chrome OS
DOCKING STATION
