USB 3.0 to DVI Graphics Adapter
CSV-2300D The SenseVision USB 3.0 to DVI Graphics Adapter is the easiest way to add a DVI-I Monitor, TV or Projector to an existing Desktop or Laptop via a single USB 3.0 Port. It works as a USB Powered external Video Card with a compact design and is an ideal solution for anyone who wants to boost their productivity by expanding their desktop space. Once the driver has been installed, the USB attached monitor can be used immediately without rebooting your system. Up to 6 USB displays are supported simultaneously*.
While the USB 3.0 to DVI Graphics Adapter is designed for USB 3.0, it’s backwards compatible with USB 2.0, however this can influence functionality.
*Under Windows. Max 2 under Apple OS X
USB 3.1 Type C to DVI-D Active Adapter
DisplayPort™ to DVI Dual Link Converter Active Adapter
USB Type-C to DP 1.2 + USB 3.0 + Type-C Charging Mini Dock
Product Name: Club 3D USB 3.0 to DVI Graphics Adapter
Product Series: SenseVision
Item Code: CSV-2300D
EAN Code: 8717249401032
UPC Code: 854365005862
• Add a DVI-I Monitor, TV or Projector through a single USB 3.0 port
• Supports resolutions up to 2048x1152p @ 60Hz
• Supports Video streaming up to 1920x1080 Full HD
• Supports Extend and Mirror display mode
• Supports up to 6 Displays under Windows
• Supports up to 4 Displays under Apple OS X
• DisplayLink DL-3100 chip inside
• USB Powered and Portable
• Works with Windows and Apple OS X
USB 3.0
Voltage
340mA approx
DVI-I Female
Club 3D USB 3.0 to DVI adapter
CD driver
USB Cable 600mm
GPU: AMD, Intel or Nvidia
RAM: 1GB or higher
USB port: 2.0/3.0
30MB of available disk space
Supported Operating Systems:
Windows 7 (32 & 64 bit)
Windows 8.1 (32 & 64 bit)
Windows 10 (32 & 64 bit)
And under Beta:
Android 5.X
Ubuntu Linux
