USB 3.0 to DisplayPort Graphics Adapter
CSV-2301 The SenseVision USB 3.0 to DisplayPort™ Graphics Adapter is the easiest way to add a DisplayPort™ Monitor, TV or Projector to an existing Desktop or Laptop via a single USB 3.0 Port.
It works as a USB Powered external Video Card with a compact design and is an ideal solution for anyone who wants to boost their productivity by expanding their desktop space. Once the driver has been installed, the USB attached monitor can be used immediately without rebooting your system. Up to 6 USB displays are supported simultaneously under Windows and max 2 under MAC OS X.
While the USB 3.0 to DisplayPort™ Graphics Adapter is designed for USB 3.0, it’s backwards compatible with USB 2.0, however this can influence functionality.
USB 3.0 to DVI Graphics Adapter
Product Name: Club 3D USB 3.0 to DisplayPort 1600P Graphics Adapter
Product Series: SenseVision
Item Code: CSV-2301
EAN Code: 8717249400981
UPC code: 854365005886
Voltage
340mA approx
DisplayPort
Club 3D USB 3.0 to DisplayPort adapter
CD driver
USB Cable
Add-on monitor, LCD or projector through a single USB 3.0 port hot-plug
Compliant with USB 3.0 Super Speed upstream connection
Supports High Resolution up to 2560x1600p at 60Hz
Video streaming is supported up to 1080p
Extend and Mirror mode support
Resumes from hibernation and suspend modes
Supports up to 6 USB display adapters to work simultaneously
Supported operating system
Windows 10
MAC OSX
