USB 3.0 to HDMI 4K UHD Graphics Adapter
CSV-2302H The SenseVision USB 3.0 to HDMI™ 4K UHD Graphics Adapter is the easiest way to add an Ultra High Definition HDMI™ Monitor, TV or Projector to an existing Desktop or Laptop via a single USB 3.0 Port.
It works as a USB Powered external Video Card with a compact design and is an ideal solution for anyone who wants to boost their productivity by expanding their desktop space. Once the driver has been installed, the USB attached monitor can be used immediately without rebooting your system. The CSV-2302H gives access to 4K UHD Displays for legacy PCs. Up to 6 USB displays are supported simultaneously under Windows and under MAC OS X max 2 USB displays are supported.
While the USB 3.0 to HDMI™ Graphics Adapter is designed for USB 3.0, it’s backwards compatible with USB 2.0, however this can influence functionality.
USB 3.1 Type C to HDMI 1.4  Active Adapter
Product Name: Club 3D USB 3.0 to HDMI™ 4K Graphics Adapter
Product Series: SenseVision
Item Code: CSV-2302H
EAN Code: 8717249401131
UPC code: 854365005992
USB 3.0 to HDMI™ 4K
Voltage
370mA approx
HDMI™
Club 3D USB 3.0 to HDM™ 4K adapter
CD driver
USB Cable
Instruction manual
Support High Resolution up to 3840x2160 pixels
Backwards compatible with HD/Legacy monitors
Access to 4K Ultra HD displays for legacy PCs
Supports up to 6 USB display simultaneously
Extend and Mirror Mode support
USB bus powered
Supported operating system
Windows 10 / 8.1
Mac OSX
