USB 3.0 to HDMI™ 4K UHD Graphics Adapter
CSV-2303H The SenseVision USB 3.0 to HDMI™ 4K UHD Graphics Adapter is the easiest way to add an Ultra High Definition HDMI™ Monitor, T V or Projector to an existing Desktop or Laptop via a single USB 3.0 Port. It works as a USB Powered external Video Card with a compact design and is an ideal solution for anyone who wants to boost their productivity by expanding their desktop space.
Once installed, the USB attached monitor can be used immediately without rebooting your system. The CSV-2303H al-lows access to 4K UHD Displays for legacy PCs. Up to 6 USB displays are supported simultaneously under Windows. Max 2 under Apple OS X. While the USB 3.0 to HDMI™ 4K UHD Graphics Adapter is designed for USB 3.0, it’s backwards compatible with USB 2.0, however this can influence functionality.
High Speed HDMI™ 1.4 HD Extension Cable  5M/ 16 ft Male/Female
Premium High Speed HDMI™ 2.0 UHD Extension Cable 3 m/ 9.84 ft Male/Female
Product Name: Club 3D USB 3.0 to HDMI™ 4K UHD Graphics Adapter
Product Series: SenseVision
Item Code: CSV-2303H
EAN Code: 8719214470166
UPC code: 841615100200
USB 3.0 to HDMI™ 4K
Power
USB Powered, operating mode uses aprox 600mA
vOutput Configuration
HDMI™ 1.4
CD driver
Instruction manual
Support High Resolution up to 3840x2160 pixels at 30Hz
Backwards compatible with HD/Legacy monitors
Access to 4K Ultra HD displays for legacy PCs
Supports up to 6 USB display simultaneously
Extend and Mirror Mode support
USB bus powered
Supported operating systems:
Windows Vista, Windows 7, Windows 8, Windows 8.1, Windows 10
Mac OS X 10.6/7/8/9/10/11/12
Android 5.0 or later
Ubuntu Linux 14.01 LTS and 16.04 LTS
Chrome R51 and later
