USB 3.0 to HDMI™ Graphics with Ethernet and 2x USB 3.0
CSV-2600 The SenseVision USB 3.0 to HDMI™ Graphics with USB 3.0 Hub and Ethernet enables a quick and convenient connection between your laptop or Ultrabook and an HDMI™ Monitor, Television or Projector. Featuring the advanced DisplayLink DL-3500 chipset, it functions as an external graphics card and delivers high quality video at resolutions up to 2048x1152p. Additionally, the integrated Gigabit Ethernet Port allows for a fast and reliable wired network connection and the two SuperSpeed USB 3.0 ports allow you to use your favorite USB peripherals and storage devices.
It’s a great tool for any power user who requires more desktop space, a faster and reliable wired network connection and more USB outputs. Works with Windows and Apple OS X. Ideal for Laptops with limited expansion ports.
USB 3.0 to HDMI 4K UHD Graphics Adapter
USB 3.0 to HDMI Graphics Adapter
Product Name: USB 3.0 to HDMI™ Graphics with Ethernet and 2x USB 3.0
Product Series: SenseVision
Weight: 140 gr
Cable length: 800 mm
Item Code: CSV-2600
EAN Code: 8719214470371
UPC Code: 841615100460
USB 3.0 Male x1
USB 2.0 Male x1
Voltage
14.43W operating power
1.95W Suspend mode
HDMI™ female
RJ45 Ethernet port
USB 3.0 female x2
SenseVision USB 3.0 to HDMI™ Graphics with Ethernet and 2x USB 3.0
Driver CD
Premium Aluminum design
Supports external HDMI™ monitor
Supports resolutions up to 2048x1152 @ 32 bit inc. 1080p Full HD
Supports 10/100/1000Mbps Ethernet
2x USB 3.0 SuperSpeed outputs
USB Bus powered
DisplayLink DL-3500 chipset inside
Supports Microsoft Windows® and Apple OS X
GPU: AMD, Intel or Nvidia
RAM: 1GB or higher
USB port: 2.0/3.0
30MB of available disk space
Supported Operating Systems:
Windows 7 (32 & 64 Bit)
Windows 8.1 (32 & 64 Bit)
Windows 10 (32 & 64 Bit)
And under Beta:
Android 5.X
Ubuntu Linux
To play DVD on the extra connected monitor through docking station, in addition to the requirements above, the following requirements should also be met:
With dual core CPU at 2.0 GHz processor clock
DOCKING STATION
