USB 3.0 to HDMI™ Graphics Adapter with USB 3.0 Hub
CSV-2602 The SenseVision USB 3.0 to HDMI™ Graphics Adapter with USB 3.0 Hub enables a quick and convenient connection between your laptop or Ultrabook and an HDMI™ Monitor, Television or Projector. Featuring the advanced DisplayLink DL-3500 chipset, it functions as an external graphics card and delivers high quality video at resolutions up to 2048x1152p.
The integrated USB hub offers 3 SuperSpeed USB 3.0 ports, allowing you to use your favorite USB peripherals and storage devices. Therefore, it is the perfect addition for the latest laptops and other devices which have limited expansion ports.
USB 3.0 to HDMI Graphics Adapter
Product Name: USB 3.0 to HDMI™ Graphics Adapter with USB 3.0 Hub
Product Series: SenseVision
Weight: 120 gr
Cable length: 80mm
Item Code: CSV-2602
EAN Code: 8719214470395
UPC Code: 841615100484
USB 3.0 Type A male x 1
USB 2.0 Type A male x 1
Voltage
14.43W operating power
1.95W Suspend mode
HDMI™ female x1
USB 3.0 Type A female x3
CD driver
Premium aluminum design
Compatible with USB 3.0 specification
DisplayLink DL-3500 chipset inside
HDMI™ resolution up to 2048x1152 @ 60Hz
Supports USB 3.0 SuperSpeed (x3)
USB bus powered
GPU: AMD, Intel or Nvidia
RAM: 1GB or higher
USB port: 2.0/3.0
30MB of available disk space
Supported Operating Systems:
Windows 7 (32 & 64 Bit)
Windows 8.1 (32 & 64 Bit)
Windows 10 (32 & 64 Bit)
And under Beta:
Android 5.X
Ubuntu Linux
To play DVD on the extra connected monitor through docking station, in addition to the requirements above, the following requirements should also be met:
With dual core CPU at 2.0 GHz processor clock
DOCKING STATION
