USB 3.0 + Dual Mini DisplayPort™ MST Docking Station
CSV-3203 The SenseVision USB 3.0 + Dual Mini DP Docking Station can easily connect to your Microsoft Surface Pro 2/3/4 Tablet or Laptop and enable connectivity to a full range of peripherals like keyboards, mice and storage devices. It has three built-in USB 3.0 ports, two MiniDisplayPort™ 1.2 outputs and one Gigabit Ethernet port. You can even extend the connections of the USB ports further to add more peripherals or USB devices. Featuring Multi Stream Transport technology, it supports dual screen setup with resolutions up to 2 x 2560x1600p 60Hz.
Dual Mode DisplayPort™ (DP++)
The MST Hub supports Dual Mode DisplayPort™ (DP++) which allows the use of DVI or HDMI™ Monitors via passive Adapters.
Flexibility
Ultrabooks, Tablets and other slim notebook computers are sleek but they often lack connectivity possibilities. With SenseVision USB3.0 + Dual Mini DP docking station you have access to all your devices through just a single USB 3.0 and Mini DisplayPort™ cable.
Add on
Get even more from your Surface Pro 2/ 3/4 tablet with its powerful Mini DisplayPort™ output. Microsoft Surface Pro tablets have powerful Intel Core CPU’s and are capable to drive up to 2 external displays using Multi Stream Transport.
Scan button
The SenseVision USB 3.0 + Dual Mini DP docking station features a scan button which can/should be used when the PC does not recognize the connected screens.
USB 3.0 to DisplayPort 4K UHD Graphics Adapter
USB 3.0 4K Docking Station
Product Name: SenseVision USB 3.0 + Dual Mini DisplayPort MST Docking Station
Product Series: SenseVision
Item Code: CSV-3203
EAN Code: 8717249401025
UPC Code: 854365005855
USB 3.0 & Mini DisplayPort 1.2
Voltage
DC 19.5V
2x Mini Displayport 1.2
3x USB 3.0 Type A
1x Gigabit Ehternet RJ45
Club 3D SenseVision USB 3.0 + Dual Mini DisplayPort MST Docking Station
CD driver
Power Adapter
• Compliant with DisplayPort™ 1.2 secifications
• Supports main link rates of 5.4Gbps (HBR2), 2.7Gbps (HBR) and 1.62Gbps (RBR)
from source
• Supports DP 1.2 Multi-Stream Transport (MST)
• Supported Max Resolutions:
For Single Screen Setup: 3840x2160 @ 60Hz
For Dual Screen Setup: 2 x 2560x1600 @ 60Hz
• Expands a USB 3.0 port to three USB 3.0 ports
• Gigabit Ethernet 10/100/1000 port
• Ethernet supports Wake-on-LAN technology, crossover detection
• Power Adapter: 100-240VAC, 50/60Hz, operating 19.5W
Windows 10, 8.1
DOCKING STATION
