USB 3.0 Dual Display Docking Station
CSV-3242HD The SenseVision USB 3.0 Dual Display Docking Station is a verstatile universal docking station which allows you to expand the outputs of your Laptop or Ultrabook so it can be used as a traditional desktop PC.
Featuring the advanced DisplayLink™ DL-3900 chip inside, the USB 3.0 Dual Display Docking Station enables the use of two external High Definition monitors via the HDMI™ and DVI-I output. It has an RJ 45 Ethernet port for a reliable, fast, wired network connection and offers a total of 6 USB ports for your peripherals and storage devices as well as an Audio and Microphone output, all linked to your device via a single USB cable.
Design:
The SenseVision USB 3.0 Dual Display Docking Station has a convenient design and detachable stand, allowing it to be placed on your desk in horizontal or vertical position. It's a productivity enhancing tool for any power user working in a (semi) professional environment.
USB 3.0 Hub 4-Port with Power Adapter
Ultra Smart Docking Station
Product Name: Club 3D Dual Display Docking Station
Product Series: SenseVision
Item Code: CSV-3242HD
EAN Code: 8717249401018
UPC code: 854365005848
USB 3.0
Voltage
14.43W operating power
1.95W Suspend mode
USB 3.0 to HDMI / DVI / 2 x USB 3.0 / 4 x USB 2.0 / Ethernet / Audio 2.1ch / Mic
CD driver
USB Cable
Power Adapter
Compatible with USB 3.0 specification
Supported Max Resolutions:
For Single Screen Setup: 2048x1152p (or 1920x1200p) @60Hz
For Dual Screen Setup: 2 x 2048x1152p (or 1920x1200p) @60Hz
Support audio 2.1 channel
Support Gigabit Ethernet
Support HDMI
Support BC1.2 charging (Front x1)
CPU: 1.6GHz single core or higher processor clock.
- Intel Pentium/Celeron family
- AMD K6/Athlon/Duron family, or compatible processor
RAM: 1GB or above
USB port: 3.0
30MB of available disk space
Supported Operating Systems:
Windows 8.1 (32 & 64 Bit)
Windows 10 (32 & 64 Bit)
To play DVD on the extra connected monitor through docking station, in addition to the requirements above, the following requirements should also be met:
With dual core CPU at 2.0 GHz processor clock
DOCKING STATION
