SenseVision USB A to HDMI™ 2.0 Dual Monitor 4K 60Hz
CSV-1474 - SenseVision USB A to HDMI™ 2.0 Dual Monitor 4K 60Hz. This unique product allows you to connect 2 Screens at 4K 60Hz to any host system with a free USB-A 3.1 Gen 1 port (USB 3.0). Featuring the next generation DisplayLink DL6950 SOC, your existing Notebook/PC- System/Mac/Tablet, is ready for the future.
HDMI™ 2.0
The Bandwidth for HDMI™ 2.0 was increased to 6 Gbps. per lane bringing the total bandwidth of the 3 integrated lanes 18 Gbps. HDMI™ 2.0 is also referred to as HDMI UHD, meaning it supports Ultra High Resolutions of up to 3840x2160p at 60Hz. HDMI™ 2.0 is downwards compatible to earlier versions however that will influence the max supported resolutions.
Product Name: Club 3D USB A to HDMI™ 2.0 Dual Monitor 4K 60Hz
Product Series: SenseVision
Item Code: CSV-1474
EAN Code: 8719214470739
UPC code: 841615100910
Input
USB A Male
Output
2 x HDMI™ 2.0 Female
• Works on any Host System with USB 3.1 Gen 1 (USB 3.0) Type A ouput.
• Not downwards compatible to earlier USB versions
• Compatible with HDMI™ 2.0 specifications
• Supported max. output resolutions:
For Dual Screen Setups: 2 x 3840x2160 at 60Hz
For Single Screen Setups: 4096x2160 at 60Hz
• Support for HDCP 2.2
• Integrated 2.0 audio and 5.1 audio
• Adapt automatically to bandwidth constraints
Voltage
USB Powered, no external power needed.
Quick Installation Guide
Operating System Support:
Notes:
-The Bandwidth for HDMI™ 2.0 was increased to 6 Gbps. per lane bringing the total bandwidth of the 3 integrated lanes 18 Gbps. HDMI™ 2.0 is also referred to as "HDMI UHD", meaning it supports Ultra High Resolutions of up to 4096x2160p at 60Hz. HDMI™ 2.0 is downwards compatible to earlier versions however that will influence the max supported resolutions.
Please contact us at [email protected] if you require more information.
