Sensevision Thunderbolt™ 3 to Dual HDMI™ 2.0
CSV-1574 - The Thunderbolt™ 3 to HDMI™ 2.0 Dual Monitor 4K 60Hz lets users easily connect two HDMI™ 2.0 Screens to any device with a Thunderbolt™ 3 interface. This unique adapter is compatible with both Mac OS Sierra™ and Windows™ 10. The output resolution supported is up to 4K @ 60Hz for Single Screen and Dual Screen setups. It is fully Plug & Play, so no need for driver installation. This stylish adapter has a beautiful Brushed Aluminum Casing making it strong and light.
It is also very slim, 16 mm, making it easy to carry with you.
Multiply your screen area with your tablet, desktop PC or Ultrabook. With multiple monitors your computer will become more useful and you will become more efficient and accomplish more. With 2 displays delivering 4 K performance, you can have four times the screen space compared to 1080p.
SenseVision Thunderbolt™ 3 to Dual Displayport™ 1.2 Adapter
SenseVision USB A to HDMI™ 2.0 Dual Monitor 4K 60Hz
Product Name: Thunderbolt™ 3 to Dual HDMI™ 2.0 Adapter
Itemcode: CSV-1574
EAN code: 8719214470746
UPC code: 841615100941
• Compatible with Thunderbolt™ 3 over USB Type C source
• Compliant to HDMI™ 2.0 specification
• Supported output resolution for single and dual outputs: up to 3840x2160p @ 60Hz
• Powered thru Thunderbolt™ 3, 15Watt, no external power needed
Mac OS™ Sierra
Windows™ 10
THUNDERBOLT TECHNOLOGY
