Mini DisplayPort™ to VGA Active Adapter
CAC-1103 The Club 3D is an active Mini DisplayPort™ to VGA signal converter. It accepts DisplayPort™ input from Mini DisplayPort™ enabled Desktop or Laptop and converts to a legacy analog VGA output allowing the use of analog VGA Televisions, Monitors and Projectors. The adapter offers hassle free plug and play functionality and is powered by the mDP output.
The Mini DisplayPort™ interface in the adapter consists of two main lanes for DP data, AUX channel, HPD signal and power. The VGA output is compliant to VSIS standard and supports up to WUXGA RB timings.
The adapter works with AMD, Nvidia and Intel Graphic Solutions and supports AMD Eyefinity™.
Mini DisplayPort™ 1.1 to HDMI™ 1.4 VR ready Passive Adapter
Mini DisplayPort™ to DisplayPort™ 1.2 2M
Mini DisplayPort™ 1.2 to HDMI 2.0
Connector 2: VGA Female
Product Name: Mini DisplayPort™ to VGA Active Adapter
Product Series: Accessories
Weight: 56 gr
Cable length: 180 mm
Item Code: CAC-1103
EAN Code:8719214470715
UPC Code: 841615100897
• Mini DisplayPort™ 1.1a compliant receiver offering 5.4Gbps bandwidth over 2 lanes
• Powered by the Mini DisplayPort™ output
• Automatic sink detection
Compatibility
Supports AMD, Nvidia® and Intel® graphics solutions
Operating Systems
Windows
In the Box
CAC-1103 Mini DisplayPort™ to VGA Active Adapter
