USB C to HDMI 2.0 UHD Cable Active M/M 1.8m/5.91ft
CAC-1514 - The Club 3D is an Active HDMI™ signal converter cable. The USB C to HDMI™ 2.0 UHD Cable is the easiest solution for connecting your USB 3.1 Type C source device featuring DisplayPort™ Alternate Mode to an HDMI™ 2.0 enabled UHD Monitor, Television or Projector. The HDMI™ adapter is powered by the USB C port, the adapter requires no external power.
The USB C to HDMI™ 2.0 UHD Cable supports (U)HD resolutions of up to 4K @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video. Use the adapter to play games, view video or browse the internet from your USB 3.1 Type-C enabled device on a (Ultra) high-resolution monitor or TV. Supporting up to 8 channels of audio, the adapter provides high-definition digital audio and video.
Compatibility
The USB C to HDMI™ 2.0 UHD Cable supports all USB 3.1 Type-C devices with DisplayPort™ ALT mode.
Please refer to your device's user manual to confirm the specification and functionality of the USB- C port.
USB 3.1 Type C to DisplayPort 1.2
Product Name: USB C to HDMI™ 2.0 UHD Cable Active Male/Male, 1.8 M./5.91 Ft.
Product Series: Accessories
Itemcode: CAC-1514
EAN code: 8719214470791
UPC code: 841615100989
• Reversible USB Type-C connector
• Compliant to VESA DisplayPort™ Alt Mode Standard
• Compliant to HDMI™ 2.0 for up to 18 Gbps data rate
• Supports 3D Video formats up to 1080p @ 120Hz
• Supports resolutions up to 3840 x 2160p @ 60Hz
Support Windows and Apple OS X
Club 3D CAC-1514 USB USB C to HDMI™ 2.0 UHD Active Cable
Input: USB Type C Male
Output: HDMI™ 2.0 male
• Boxsize: 145 X 145 x 45 mm.
• Cable: 1800 x 22 x 10 mm.
• Weight: 65 gr.
• ESD bag: 8 gr.
• Retail box including cable and ESD, 100 gr.
