USB 3.1 Gen2 Type-C to Type-B Cable M/M 1m/3.28ft
CAC-1524 - The Club 3D USB 3.1 Gen2 Type-C to Type-B Cable enables the connection of your existing USB peripherals, Printers, External HDD's, Docking Stations, etc. with the common Type B connector plug, to the latest Laptops, tablets and Ultrabooks featuring USB Type C outputs.
The cable is backwards compatible and supports USB 3.0 and USB 2.0 as well. The USB 3.1 specification ensures a bitrate of 10Gbps for fast transfer of large files.
USB C to HDMI 2.0 UHD Cable Active M/M 1.8m/5.91ft
USB 3.1 Type-C Cable 10Gbps 4K60Hz PD 100W M/M 0.8m/2.62ft
USB 3.1 Type-C to Type-A Cable 10Gbps PD 60W M/M 1m/3.28ft
Product Name: USB 3.1 Gen2 Type-C to Type-B Cable 1M./3.28 Ft. M/M
Product Series: Accessories
Itemcode: CAC-1524
EAN code: 8719214470838
UPC code: 841615101023
• Connect USB Type B devices to USB 3.1 Type C enabled Laptops, Tablets and Ultrabooks.
• USB 3.1 data transfer rates up to 10Gbps when used with USB 3.1 host and device
• Backwards compatible to support USB 3.0 and USB 2.0 specification.
• Thunderbolt 3 port compatible
• Maximum power support is 30 V./3 A.
• Supports all operating systems
Input: USB Type C Male
Output: USB Type B Male
• Boxsize: 145 X 145 x 45 mm.
• Cable: 1000 x 14 x 10 mm.
• Weight: 42 gr.
• ESD bag: 3 gr.
• Retail box including cable and ESD, 100 gr.
THUNDERBOLT TECHNOLOGY
