DisplayPort 1.4 to DisplayPort 1.4 M/M 1m/3.28ft
CAC-2067 The Club 3D DisplayPort™ 1.4 HBR3 cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device.
DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage. The Cable is 28AWG and fully Bi-Directional.
MiniDisplayPort to DisplayPort 1.2 Cable M/M 2m/6.56ft
Product Name: DisplayPort™ 1.4 HBR3 Cable 8K60Hz Male / Male 1m/3.28ft
Product Series: Cables
Item Code: CAC-2067
EAN Code: 8719214470814
UPC Code: 841615101009
• Support resolutions up to 8K @ 60Hz
Operating System Support:
All
Maximum resolution:
- 8K @ 60Hz
- 4K @ 120 Hz
Without compression (DSC) DisplayPort 1.4 can support up to:
- 5K @ 60Hz
Connector 1:
DisplayPort™ Male
Connector 2:
DisplayPort™ Male
• Plastic Bag size: 215 x 150 x 18 mm.
• Plastic Bag Weight: 6 gr.
• Cable Weight: 76 gr.
• Cable height: 12 mm.
• Cable width: 19 mm.
• Cable Size: 1 meter/3.28 feet
DisplayPort™ 1.4 HBR3 Cable 8K60Hz Male / Male 1M/3.28Ft
POSSIBLE RESOLUTIONS
