DisplayPort 1.4 HBR3 Cable M/M 2m/6.56ft.
CAC-2068 The Club 3D DisplayPort™ 1.4 HBR3 cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one- touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage. The Cable is 28AWG and fully Bi-Directional.
Certified by VESA.
DisplayPort™ to Mini DisplayPort™ 1.2  Cable M/M 2m/6.56ft
MiniDisplayPort 1.4 HBR3 Cable M/M 2m/6.56 Ft.
Product Name: DisplayPort 1.4 HBR3 8K60Hz Cable M/M 2m/6.56ft.
Product Series: Cables
Item Code: CAC-2068
EAN Code: 8719214470821
UPC Code: 841615101016
• Support resolutions up to 8K @ 60Hz
• Certified by VESA
Operating System Support:
All
Maximum resolution:
- 8K @ 60Hz
- 4K @ 120 Hz
Without compression (DSC) DisplayPort 1.4 can support up to:
- 5K @ 60Hz
Connector 1:
DisplayPort™ Male
Connector 2:
DisplayPort™ Male
• Plastic Bag size: 215 x 150 x 18 mm.
• Plastic Bag Weight: 6 gr.
• Cable Weight: 135 gr.
• Cable height: 12mm.
• Cable width: 19 mm.
• Cable Size: 2 meter/6.56 feet
DisplayPort™ 1.4 HBR3 Cable 8K60Hz Male/Male 2M/6.56Ft
POSSIBLE RESOLUTIONS
