USB 3.1 Type C to Mini DisplayPort 1.2 and PD 60 W Adapter
CAC-1509 - The Club 3D CAC-1509 is a DisplayPort™ signal converter. The USB 3.1 Type C to Mini DisplayPort 1.4(When source supports it) and PD 60W Adapter is the easiest solution for connecting your USB 3.1 Type C source device featuring DisplayPort™ Alternate Mode to a Mini DisplayPort™ 1.4 enabled Ultra High Definition Monitor, Television or Projector. The DisplayPort™ adapter is compact and highly portable. Powered by the USB C port, the adapter requires no external power and is ideal for use with the latest notebooks and Ultrabooks. This signal converter works also with DP1.2.
The USB 3.1 Type C to Mini DisplayPort™ 1.4(When source supports it)and PD 60W Adapter supports UHD resolutions up to 4K UHD @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video.
Power
The USB C female port can charge the host computer up to 60W (20V/3A).
Compatibility
It is compatible with new Apple Macbook Pro, Macbook, new Google Chromebook Pixel and other USB-C supported devices with support for DisplayPort™ Alternate Mode over USB C.
USB 3.2 Gen1 Type C to DisplayPort 1.2 4K60Hz
Product Name: USB 3.1 Type C to Mini DisplayPort 1.2 and PD 60W Adapter
Product Series: Adapter
Itemcode: CAC-1509
EAN code: 8719214470883
UPC code: 841615101078
• Reversible USB Type-C connector
• Compliant to VESA DisplayPort™ 1.4 Alternate Mode
• Supports UHD resolutions up to 4096x2160p @ 60Hz
• Supports 3D Video formats up to 1920x1080p @ 120Hz
• Supports content protection, HDCP 2.2
• USB Type C Female Charging Port, Upstream Power Delivery Up to 60W (20V/3A)
Compatibility
Supports AMD HD 6xxx, Nvidia® Maxwell and Intel® HD/ Iris™ graphics solutions and newer.
Requires DisplayPort™ Alt Mode support from the source system.
• USB type C male
• Mini DisplayPort™ 1.4 female
• USB Type C for Power Delivery
Microsoft Windows
Google Chrome OS
• Packing Size: 145 x 145 x 45 mm.
• Packing Weight: 6 gr.
• Adapter Weight: 23gr.
• Adapter height: 11 mm
• Adapter width: 42 mm
• Adapter length: 183 mm
• Meets ROHS, FCC, and CE EMI requirement
Club3D USB 3.1 Type C to Mini DisplayPort 1.4 and PD 60W Adapter
POSSIBLE RESOLUTIONS
