Mini DisplayPort 1.2 HBR2 Cable M/M 2m/6.56ft
CAC-2161 - The Club 3D Mini DisplayPort™ cable enables the connection of your Mini DisplayPort™ supported (Gaming) PC or Laptop to an Ultra High Resolution Monitor or other Mini DisplayPort™ supported device.
The Club 3D CAC-2161 is fully compatible to Displayport™ 1.2 specifications and is downwards compatible to earlier versions.
The soft UltraFlex jacket protects the cable from bending- and deformation damage.
MiniDisplayPort 1.4 HBR3 Cable M/M 2m/6.56 Ft.
MiniDisplayPort to DisplayPort 1.2 Cable M/M 2m/6.56ft
Product Name: Mini DisplayPort™ 1.2 HBR2 Cable M/M 2m/6.56ft 32 AWG
Product Series: Cables
Itemcode: CAC-2161
EAN code: 8719214470968
UPC code: 841615101153
• Compliant to DisplayPort™ 1.2a specifications
• Downwards compatible to earlier versions
• Supports monitor resolutions up to 4096x2160 @ 60Hz and 3D video
• Supports all UHD TV resolutions including 1080p FHD and 4K UHD
• Supports HBR2; up to 5.4 Gbps per lane - 21.6 Gbps total
All
Mini DisplayPort™ 1.2 Male
• Poly Bag: : 215 x 150 x 18 mm.
• Poly Bag Weight: 6gr.
• Cable Weight: 70gr.
• Cableheight: 12mm.
• Cable width: 19 mm.
• Cable Size: 2 meters / 6.5 feet
Club 3D Mini DisplayPort™ 1.2 HBR2 Cable M/M 2m/6.56ft 32 AWG
POSSIBLE RESOLUTIONS
