CAC-2312 - The Club 3D HDMI™ 2.0 4K60Hz UHD Cable enables the connection of your HDMI™ supported Gaming PC or Laptop to an (Ultra) High Definition Monitor or other HDMI™ supported device.
It fully supports the HDMI™ with Ethernet specification, ensuring that video up to 4K UHD, 4096x2160p at 60Hz is supported, as well as HDR, audio and data streams.
The 5 meter/16.40 feet cable combines the unmatched signal quality and convenience of HDMI™ connectivity with the power and flexibility of home entertainment networking.
It includes a dedicated data channel into the HDMI™ link, enabling high speed networking at up to 100 Mbps. It is the ideal solution for the ultimate future proof HDMI™ 4K UHD Gaming and Viewing experience.
Product Name: HDMI™ 2.0 4K60Hz UHD Cable 5m/16.40ft Male/Male
Product Series: Cables
Itemcode: CAC-2312
EAN code: 8719214470920
UPC code: 841615101115
• Compliant to HDMI™ with Ethernet specification version 2.0
• Professional quality braided cable with Metal connector head
• Supports UHD TV resolutions up to 4096x2160p @ 60Hz and HDR
• Supports up to 32 audio channels for the total audio experience
• Supports up to 1536 KHz audio sample frequency for the highest audio fidelity
• Fully Bi-Directional
All
HDMI™ Male
HDMI™ Male
• Packaging size: 25 x 21 x 4.2cm / 9.84 x 8.27 x 1.65"
• Poly Bag Weight: 10 gr.
• Product Weight: 350 gr.
• Product height: 12mm.
• Product width: 19 mm.
• Product Length: 5 meter/16.40 feet
Club 3D HDMI™ 2.0 4K60Hz UHD Cable 5m/16.40ft
-HIGH DEFINITION AND MORE
POSSIBLE RESOLUTIONS
