HDMI 2.0 4K60Hz RedMere cable 10m/32.81ft
CAC-2313 - The Club 3D HDMI™ 4K60Hz UHD RedMere® Cable enables the connection of your HDMI™ supported Gaming PC or Laptop to an Ultra High Definition Monitor or other HDMI™ supported device.
Although the cable is 10 meters / 32.81 feet long, it fully supports the HDMI™ 2.0 with Ethernet specification, ensuring that video up to 4K UHD, 4096x2160p at 60Hz is supported, as well as audio and data streams.
RedMere® Technology
The CAC-2313 contains Active Chips with HDMI™ in-cable equalisation technology, with advanced signal processing allowing to support wide band data across relative thin and long cables while maintaining compatibility with the next generation of HDMI™ 2.0 devices. Because of the active receiver and transmitter inside this cable it is not bi-derectional.
Micro HDMI to HDMI 2.0 4K60Hz Cable M/M 1m/3.28ft
Product Name: HDMI™ 2.0 4K60Hz RedMere® cable 10m/32.81ft
Product Series: Cables
Itemcode: CAC-2313
EAN code: 8719214470937
UPC code: 841615101122
• Compliant to HDMI™ 2.0 with Ethernet specification
• Professional quality braided cable with Metal connector head
• Supports up to 32 audio channels for the total audio experience
• Supports up to 1536 KHz audio sample frequency for the highest
• Contains Active Chips with in-cable equalisation technology
• The CAC-2313 cable is not bidirectional
All
HDMI™ Male
HDMI™ Male
• Poly Bag size: 350 x300 x 18 mm.
• PolyBag Weight:12gr.
• Product Weight: 700 gr.
• Product Height:12mm.
• Product width: 19 mm.
• Product Length: 10 meter/ 32.81 feet
Club 3D HDMI™ 2.0 4K60Hz RedMere® cable 10m/32.81ft
POSSIBLE RESOLUTIONS
