HDMI 2.0 4K60Hz RedMere cable 15m/49.2ft
CAC-2314 - The Club 3D HDMI™ 2.0 4K60Hz UHD RedMere® Cable enables the connection of your HDMI™ supported Gaming PC or Laptop to an (Ultra) High Definition Monitor or other HDMI™ supported device.
Although the cable is 15 meters / 49.2 feet long, it fully supports the HDMI™ 2.0 with Ethernet specification, ensuring that video up to 4K UHD, 4096x2160p at 60Hz is supported, as well as audio and data streams.
RedMere® Technology
The CAC-2314 contains Active Chips with HDMI™ in-cable equalisation technology, with advanced signal processing allowing to support wide band data across relative thin and long cables while maintaining compatibility with the next generation of HDMI™ 2.0 devices.
HDMI 2.0 4K60Hz RedMere cable 10m/32.8ft
Product Name: HDMI™ 2.0 4K60Hz UHD RedMere® Cable 15 m/49.2ft Male/Male
Product Series: Cables
Itemcode: CAC-2314
EAN code: 8719214470944
UPC code: 841615101139
• Compliant to HDMI™ with Ethernet specification version 2.0
• Professional quality braided cable with Metal connector head
• Supports up to 32 audio channels for the total audio experience
• Supports up to 1536 KHz audio sample frequency for the highest audio fidelity
• Contains Active Chips with in-cable equalisation technology
All
HDMI™ Male
HDMI™ Male
• Poly Bag size: 350 x300 x 18 mm.
• Poly Bag Weight: 12gr.
• Product Weight: 1000gr.
• Product Height: 12mm.
• Product Width: 19 mm.
• Product Length: 15meter/ 49.2feet
Club 3D HDMI™ 2.0 4K60Hz UHD RedMere® Cable 15 m/49.2ft Male/Male
POSSIBLE RESOLUTIONS
