Mini DisplayPort 1.4 to HDMI 2.0b HDR
CAC-1180 - The Club3D is a Mini DisplayPort™ 1.4 to HDMI™ 2.0b signal converter. It features support for HDR Video quality for deep color media content playback. The Mini DisplayPort™ receiver supports up to 5,4 Gbps per lane over 4 lanes. The HDMI™ output is fully compliant to HDMI™ specification version 2.0b.Supports up to 4K UHD Resolutions. The CAC-1180 supports UHD resolutions up to 4096 x 2160p at 60Hz.
Color Formats
It supports RGB/YCbCr video color formats with a color depth of 16bpc (or 48 bits per pixel) as long as it fits within the Mini DisplayPort™ and HDMI™ link bandwidth. The CAC-1180 also supports pixel encoding conversion from RGB or YCbCr 4:2:2 to YCbCr 4:2:0 and YCbCr 4:2:0 pass-trough function. In addition HDR with deep color up to 12Bpc at 4K 60Hz is supported through the conversion of RGB/YCbCr 4:2:2 over DP link to YCbCr 4:2:0 on the HDMI™ output with a horizontal expansion to CEA timings.
Product Name: Mini DisplayPort™ 1.4 to HDMI™ 2.0b HDR Active Adapter
Product Series: Adapters
Itemcode: CAC-1180
EAN code: 8719214470869
UPC code: 841615101054
Windows 10, 8.1,
• Club 3D Mini DisplayPort™ 1.4 to HDMI™ 2.0b HDR Active Adapter
• Mini DisplayPort™ 1.4 male
• HDMI™ 2.0b female
• Box size: 182 x 60 x 35mm.
• Cable: 168.6 x 20 x 11 mm.
• Weight: 30 gr.
• Video Stream Handling
- RGB/YCbCr 4:2:2/4:2:0 pixel format
• Audio Stream Handling
• HDCP Support
• HDMI™ transmitter
- Compliant to HDMI™ specifications version 2.0b
- 4K 60Hz YCbCr 4:2:0, up to 12bpc
- 4K 30Hz RGB/YCbCr 4:2:2, up to 12bpc
POSSIBLE RESOLUTIONS
