USB 3.1 Type C to HDMI 2.0 UHD 4K 60Hz Active Adapter
CAC-2504 - The Club 3D CAC-2504 is an Active HDMI™ signal converter. The USB 3.1 Type C to HDMI™ 2.0 UHD 4K 60Hz HDR Active Adapter is the easiest solution for connecting your USB 3.1 Type C source device featuring DisplayPort™ 1.4 Alternate Mode to an HDMI™ 2.0 enabled UHD Monitor, Television or Projector. It features support for HDR Video quality for deep color media content playback. The DisplayPort™ receiver supports up to 5,4 Gbps per lane over 4 lanes.
The USB 3.1 Type C to HDMI™ 2.0 UHD 4K 60Hz Active Adapter supports UHD resolutions of up to 4K @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video. Use the adapter to play games, view video or browse the internet from your USB 3.1 Type-C enabled source system on a (Ultra) high-resolution monitor or TV. Supporting up to 8 channels of audio, the adapter provides high-definition digital audio and video.
The USB 3.1 Type C to HDMI™ 2.0 UHD 4K 60Hz HDR Active Adapter supports all USB 3.1 Type-C source systems with DisplayPort™ Alternate Mode and operating systems, including Apple OS X, Windows 8.1 and 10 and Google Chrome OS.
USB 3.2 Gen1 Type C to DisplayPort 1.2 4K60Hz
USB C to HDMI 2.0 UHD Cable Active M/M 1.8m/5.91ft
Product Name: USB 3.1 Type C to HDMI™ 2.0 UHD 4K 60Hz HDR Active Adapter
Product Series: Adapter
Itemcode: CAC-2504
EAN code: 8719214471026
UPC code: 841615101214
• Reversible USB Type C Connector
• Video Stream Handling
- RGB/YCbCr 4:2:2/4:2:0 pixel format
• Audio Stream Handling
• HDCP Support
- HDCP 1.3 to HDCP 1.4 repeater function
- HDCP 2.2 to HDCP 1.4 and 2.2 repeater function
• HDMI™ transmitter
- Compliant to HDMI™ specifications version 2.0 b
- 4K 60Hz YCbCr 4:2:0, up to 12bpc
- 4K 30Hz RGB/YCbCr 4:2:2, up to 12bpc
Note: For HDR to function, the source system needs to support DisplayPort™ 1.4
Alternade Mode and the screen needs to have support for HDR and/or HDMI™ 2.0 a or b.
USB type C male
HDMI™ 2.0 female
Windows 8.1, 10, Apple OS X
• Packaging size: 18 x 11 x 1.8cm /7.1 x 4.3 x 0.71"
• Poly Bag Weight: 10 gr.
• Product Weight: 21 gr.
• Total Weight: 31 gr.
• Adapter size: 180 x 37 x 15 mm.
Club 3D CAC-2504 USB 3.1 Type C to HDMI™ 2.0 UHD 4K 60Hz HDR Active Adapter
POSSIBLE RESOLUTIONS
