DVI to HDMI 1.4 Cable M/M 2m/ 6.56ft Bidirectional
CAC-1210 - The Club 3D CAC-1210 is a DVI to HDMI™ 1.4 Adapter Cable. Because this Adapter Cable is fully Bi-Directional, it can also be used as a HDMI™ to DVI Adapter Cable.
This CAC-1210 Cable is the easiest solution for connecting your HDMI™ Monitor, Projector or Television to the DVI output of your PC / Notebook or to connect your DVI Monitor, Projector or Television to the HDMI™ output of your PC / Notebook / Game Console.
The CAC-1210 uses premium components and gold plated contacts to ensure the highest performance and maximum ease of use resulting in the best user experience with resolutions up to UHD / 3840 x 2160 @ 30Hz.
DVI-D to HDMI Passive Adapter
Product Name: DVI to HDMI™ Cable M/M 2m / 6.56ft
Product Series: Cables
Itemcode: CAC-1210
EAN code: 8719214471033
UPC code: 841615101221
• Compliant to DVI-D D Dual Link specification
• Supports resolutions up to UHD / 3840 x 2160 @ 30Hz
• Fully Bidirectional
• No external power needed
• Plug & Play
All
CAC-1210, DVI to HDMI™ 1.4 Cable M/M 2m / 6.56ft, Bidirectional
• DVI Male
• HDMITM Male
• Boxsize:145x145x45mm.
• WEIGHT PRODUCT(gr) 104
• WEIGHT BOX(gr): 51
• WEIGHTPRODUCTWITH BOX(gr):155
• Cable length (mm) 2000
• Cable length (ft) 5.56
• Cable height (mm) 14
• Cable width (mm) 39
POSSIBLE RESOLUTIONS
