CAC-1502 The Club 3D CAC-1502 is an Active VGA signal converter. This USB-C to VGA Active Adapter is the easiest solution for connecting your USB 3.1 Type C source device featuring DisplayPort™ Alternate Mode to a VGA enabled Monitor or Projector. The VGA adapter is compact and highly portable. Powered by the USB-C port, the adapter requires no external power and is also ideal for use with notebooks and Ultrabooks.
Supports up to WUXGA Resolution (1920x1200 pixels).
The USB-C to VGA adapter supports HD resolutions of up to Full HD (1080p) for a clear, sharp picture. The support of 60FPS (frames per second) provides exceptionally smooth video. Use the adapter to play games, view video or browse the internet from your USB-C enabled device on a high-resolution VGA Display Device.
Compatible with all Operating Systems.
The USB-C to VGA Adapter supports all USB-C devices with DisplayPort™ ALT mode and operating systems, including Apple OS X, Windows 7, 8.1 and 10 and Google Chrome OS.
Please refer to your device's user manual to confirm the specification and functionality of its USB-C port.
USB 3.2 Gen1 Type C to Gigabit Ethernet Active Adapter
Mini HDMI to HDMI 4K60Hz Cable M/M 1 m/ 3.28 ft
Product Name: USB 3.1 Type-C to VGA Active Adapter
Product Series: Adapter
Weight: 56 gr
Cable length: 180 mm
Item Code: CAC-1502
EAN Code: 8719214470081
UPC Code: 841615100170
• Reversible USB 3.1 Type C connector
• Compliant to VESA DisplayPort Alt Mode Standard
• Compliant to VGA analog display standard with 15 pin D-Sub conn
• Supports Monitor resolutions up to WUXGA 1920 x 1200p @ 60Hz
• Powered by USB port (no external power needed)
Compatibility
Supports AMD HD 6xxx, Nvidia® Maxwell and Intel® HD/ Iris™ graphics solutions and newer.
Requires DisplayPort™ Alt Mode support from the source system.
Connector 1
USB 3.1 Type C Male
Connector 2
VGA Female
Operating Systems
Microsoft Windows
Google Chrome OS
In the Box
Club 3D CAC-1502 USB 3.1 Type-C to VGA Active Adapter
