USB3.2 Gen1 UHD 4K Docking Station DisplayLink® Certified
The Club 3D CSV-3103D is an Universal USB 3.2 Gen1 UHD 4K Docking station is designed for all your connectivity needs. With the built-in USB 3.2 Gen1 ports, the docking station enables you to enjoy the super speed data transmission (up to 5Gbps) of your USB peripherals, reducing cable clutter and bringing data and DisplayLink® Certified connectivity to your notebook or tablet via a single USB 3.2 Gen1 uplink port.
DisplayLink® Certified Dual Monitor support allows you to chose from either the DP™ or HDMI™ output plus a DVI-D output. It supports Display resolution up to 4K at 30Hz for single Monitor setup or full HD at 60Hz for Dual Monitor setups. It offers separate connections for your Speakers or Headset and Microphone. You can even charge your Mobile Phone thru the BC1.2 Fast Charge Port in a manner of minutes.
Functionality is also dependent on the functionality of the connected devices.
USB 3.1 Hub 4-Port with Power Adapter
USB3.2 Gen1 Type A or C Dual Display 4K60Hz Docking Station
Product Series: Docking
Product Code: CSV-3103D
EAN code: 871724940107
UPC code: 84365005954
• DisplayLink® Certified
• Featuring DisplayLink® DL-5900 SoC with Dual Monitor Support
• DP™ or HDMI™ resolution up to 3840 x 2160 @30Hz
• DVI-D resolution up to 2048 x 1152 @60hz
• Compatible with USB 3.2 Gen1/2.0 specification
• Audio 2.1 channel connection 3.5mm Jack
• Microphone connection 3.5mm Jack
• Supports Gigabit Ethernet 10/100/1000
• 3 x USB 3.2 Gen1 output ports
• Supports BC 1.2 charging for fast charging your compatible devices
• Windows® 10/8.1, MAC® OSX
• USB 3.2 Gen1 UHD 4K Docking Station DisplayLink® Certified
• External Power Supply 100-240VAC, 135W, PowerCord (specify plug when ordering)
• USB3.2 Gen1 Type-A to Type-B cable 1m/3.28ft
• Quick Installation Guide
• 1x USB3.2 Gen1 Female
• 3x USB3.2 Gen1 with 1x BC 1.2 charging Female
• 1x HDMI™ Female
• 1x DisplayPort™ Female
• 1x DVI-D Female
• 1x Ethernet Female
• 1x 3.5 mm Jack 2.1 ch Female
• 1x 3.5 mm Jack Mic Female
• Box size: 29.8 x 15 x 9.2 cm/11.73 x 5.9 x 3.62"
• Hub size: 18.9 x 7.45 x 2.63 cm/7.44 x 2.93 x 1.04"
• Cable Length: 1m/3.28ft
• Box Weight: 177gr./ 6.24 oz.
• Device Weight: 187 gr./ 6.6 oz.
• Power Supply Weight: 175 gr./ 6.17 oz.
• USB Cable Weight: 42 gr./ 1.48 oz.
• Total Weight: 581 gr./ 20.49 oz.
Warning Safe Usage: Only to be used at altitude 2000 meters/6562 feet and below.
Note:
