DisplayPort™ 1.4 HBR3 Cable VESA Certified  M/M 2 m / 6.56ft 28AWG
The Club 3D CAC-2068 DisplayPort™ 1.4 HBR3 VESA Certified Cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device to Support resolutions up to 8K60Hz. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32. It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
Mini DisplayPort 1.4 HBR3 Cable M/M 2m / 6.56ft 34 AWG
Product Series: Cables
Product Code: CAC-2068
EAN code: 8719214470821
UPC code: 841615101016
• VESA Certified
• Support resolutions up to 8K60Hz
• All
• CAC-2068 DisplayPort™ 1.4 HBR3 Cable VESA Certified M/M 2 m / 6.56ft 28AWG
• DisplayPort™ 1.4 Male
• Packaging size: 21.5 X 15 x 3.2 cm/ 8.46 x 5.9 x 1.26"
• Poly Bag Weight: 7 gr / 0.25 oz
• Product Weight: 132 gr / 4.66 oz
• Product height: 1.2 cm / 0.47"
• Product width: 1.9 cm / 0.35"
• Product Length: 2 m / 6.56 ft
POSSIBLE RESOLUTIONS
-HIGH DEFINITION AND MORE
