CAC-1060 - The Club 3D DisplayPort™ 1.4 HBR3 8K cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution
Monitor or other DisplayPort™ supported device. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
DisplayPort 1.4 HBR3 Cable Male/Male 1m/3.28ft 28AWG
DisplayPort™ 1.4 HBR3 8K Cable Male/Male 3M / 9.84ft.
Product Series: Cables
Itemcode: CAC-1060
EAN code: 8719214471095
UPC code: 841615101283
• Fully DisplayPort™ 1.4 Compliant, HBR3, 32.4Gbps, 28AWG
• Without DSC1.2 max resolution supported up to: - 5K @ 60Hz
• Vesa Certified
• DisplayPort™ 1.4 Male
• Box size: 210 x 210 x 50 mm.
• Box Weight: 64 gr.
• Product Weight: 219 gr.
• Weight Product with retail box: 283 gr.
• Product height: 12mm.
• Product width: 19 mm.
• Product Length: 3meter/ 9.84feet
Club 3D DisplayPort™ 1.4 HBR3 8K Cable
