Ultra High Speed HDMI™ Cable 4K120Hz 8K60Hz 48Gbps M/M 2 m./6.56 ft.
CAC-1372 - The Club 3D Ultra High Speed HDMI™ Cable is build to handle the highest quality video- and audio signals.
HDMI Increased Bandwidth to 48Gbps.
The increase in maximum bandwidth compared to previous versions is
achieved by increasing both the bitrate of the data channels (from 6Gbps
to 12Gbps) and the number of channels (from 3 to 4). This allows support
for resolutions up to supports 4K120Hz 8K60Hz !
New feature included in this Specification is Display Stream Compression
(DSC) 1.2 , this is used for video formats higher than 8K with 4:2:0.
-Variable Refresh Rate (VRR) reduces or eliminates lag, stutter and frame
tearing for more fluid motion in games
-Quick Media Switching (QMS) for movies and video eliminates the delay that
can result in blank screens before content is displayed
-Quick Frame Transport (QFT) reduces latency.
HDMI also supports Static- and Dynamic HDR metadata.
All HDMI features are fully supported by this Club3D CAC-1372 Cable. It is
the ideal solution for the ultimate future proof HDMI™ experience.
Premium High Speed HDMI™ 4K60Hz UHD Cable M/M 1 m / 3.28 ft 30AWG
Product Name: Ultra High Speed HDMI™ 4K120Hz 8K60Hz Cable 48Gbps Male/Male 2 m./6.56ft.
Product Series: Cable
Itemcode: CAC-1372
EAN code: 8719214471156
UPC code: 841615101344
• Fully Compliant to Ultra High Speed HDMI™ specification
• Professional quality cable
• Gold plated connectors for maximum conductivity and 28 AWG
• Supports (U)HD resolutions up to 4K120Hz 8K60Hz (with DSC 1.2)
• Supports Static- and Dynamic HDR Metadata
All
• HDMI™ Male
• HDMI™ Male
• Box size: 145 x 145 x 45 mm.
• Box Weight: 46 gr.
• Product Weight: 118 gr.
• Cable + Bag : 127 gr.
• Product + Box + Bag Weight: 173 gr.
• Product height: 12mm.
• Product width: 22 mm.
• Product Length: 2 meter/ 6.56 feet
In the box: Ultra High Speed HDMI™ 4K120Hz 8K60Hz Cable 48Gbps Male/Male 2 m./6.56 ft.
POSSIBLE RESOLUTIONS
