HDMI 2.0 UHD Active Optical Cable HDR 4K 60Hz M/M 30m/98.42ft
CAC-1390 - The Club 3D HDMI™ 2.0 Hybrid Active Optical Cable features both fiber- and copper conductors, providing a lighter, more flexible cable construction, which makes it ideal for installation in narrow spaces and over longer distances. The perfect solution for conference rooms, classrooms, digital signage displays, and more.
This CAC-1390 features a built-in booster circuit that is self-powered through the HDMI ports, allowing you to connect your HDMI-enabled devices at a distance of up to 30 meters with no signal loss.
The cable is Halogen Free, and produced according to the International Electrochemical Commission's Restriction Use of Halogen (IEC 61249-2-21) directive.
This cable features unidirectional architecture, which requires that the cable is installed in the correct direction. Please refer to the source and display labels on the HDMI™ connectors, in order to ensure that the cable is connected properly.
HDMI 2.0 UHD Active Optical Cable HDR 4K 60Hz M/M 50m/164,04ft
Product Name: HDMI™ 2.0 Hybrid Active Optical Cable HDR 4K 60Hz M/M 30m/98.42ft
Product Series: Cables
Itemcode: CAC-1390
EAN code: 8719214471071
UPC code: 841615101269
• Compliant to HDMI™ specification version 2.0b (600Mhz Clock Frequency)
• Total Data bandwidth of 18Gbps
• Supports Dolby® True HD, DTS-HD Master Audio up to 32 audio channels
• Halogen Free and without EMI/RFI emission
• Support for HDR/HDCP/EDID/CEC/DDC
• Plug and Play, no driver software required
• Unidirectional - meaning Source and Display only
• This cable is Hybrid which makes it downwards compatible to other HDMI versions
All
HDMI™ 2.0 Male
HDMI™ 2.0 Male
• Box size: 230 x 230 x 80 mm.
• Box Weight: 132 gr.
• Product Weight: 835 gr.
• Cable + Bag : 852 gr.
• Product + Box + Bag Weight: 984 gr.
• Product height: 70 mm.
• Product width: 170 mm.
• Product Length: 30 meter/ 98.42 feet
• HDMI™ 2.0 Hybrid Active Optical Cable HDR 4K 60Hz M/M 30m/98.42ft
